On the printer operating panel, press the Options
button twelve (12) times until Set Defaults appears
on the LCD.
When you see the Use Factory option on the
display, press Select. The printer should now be
reset to the default settings.
Be aware that this will not clear up any issues related to problematic ink cartridges ink levels...
You can fix that issue by doing the following: just put the tape into the terminal and run cleaning process the printer
will tell you that your cartridge is incorrect, just ignore it and
removed the tape and try to print again and it will read the cartridge
as new one.
If that does not work then try ordering a new cartridge
LEXMARK X7170 INK CARTRIDGES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
