Macally BTMicro Mouse Logo
Question about Macally BTMicro Mouse
How do I pair a Bluetooth C1311B Mouse, there is no connect button on the bottom of the mouse just a power on/off switch ?
Wireless Bluetooth Optical Mouse 1000DPI for Laptop Notebook Computer C1311B http://www.ebay.com/itm/10M-Optical-Bluetooth-Mouse-Wireless-Mice-1000DPI-For-Laptop-Notebook-Computer-B-/200686361070?pt=UK_Computing_ComputerComponents_JoysticksJoypadsGamepads&hash=item2eb9d6d9ee
  • CjBruh21 :D
    CjBruh21 :D Jul 09, 2016
    You have to click the two buttons on the side and the scroll button for around 1 or 2 seconds
Radu Nemtanu
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 44 Answers
You have to press both left and right button and the middle.
Posted on Sep 12, 2012
  • 1 more comment
  • Anonymous Sep 13, 2012
    Thank you, worked like a charm !!!
  • Anonymous Oct 22, 2012
    thank you so much it worked perfectly !
  • axillman144
    axillman144 Jan 15, 2013
    my computer doesn't recognize the bluetooth mouse
2 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Posted on Nov 23, 2007
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: Pairing my Macally BT micro mouse
How do I start the pairing process on the mouse?
It's a bluetooth mouse. It does not have a USB receiver. There is a combination of buttons that you press on the mouse. That is what i am looking for.
Can anyone help?
My hp wireless optical mouse stopped working, even with new batteries. please provide a DETAILED step-by-step process for resetting it. i know it involves pressing buttons on the bottom of the mouse and...
namastey!
*clean the bottom of a mouse and if the lens gets dirty wipe it with the soft dampened cloth
* replace the batteries
*Reinstall wireless drivers. If your mouse came with a CD, re-insert it into your computer's disc drive and install all software and drivers.Disable internal transceiver. If your wireless mouse connects to an internal Bluetooth transceiver, disable it using the Bluetooth utility in the Control Panel, and then re-enable it after a few minutes. Then try connecting your wireless mouse.
1helpful
Dynex wireless mouse with new batteries (kodak AAA) inserted properly fails to move the cursor. Mouse barely used, purchased last year at Best Buy, Hadley MA
Make sure the mouse is turned on (power switch on the bottom) and then reconnect it with the USB receiver. Press the Connect button on the receiver, then press the Connect button on the bottom of the mouse.
Changing the batteries does not make the mouse work. the cursor is visible on the screen but will not move. what next?
Have you tried re-pairing your mouse? Should be a button on the bottom of the mouse and a button on the wireless antenna device. Or, If your using a bluetooth mouse make sure bluetooth is turned on, on your computer.
3helpful
My laser logitech bluetooth mouse won't connect to the laptop again
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Mouse
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth Mouse will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
3helpful
2answers
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
My bluetooth mouse used to connect but now it doesn't...When I press the blue button, the blue light does not blink like it used to. Is my bluetooth mouse dead? (fresh batteries, and it turns on).
Mostlikely you need to repair the mouse with the computer. open your bluetooth utility or the keyboard/mouse utility and follow the pairing instructions. this should solve your problem
Mouse stopped working..changed the batteries..was working, now it
on your computer screen at the bottom right corner, there should be a bluetooth icon (if your mouse is a bluetooth mouse) right click the bluetooth icon select ADD a device. after that follow the prompts, at some point it will ask you to have the bluetooth device be discoverable, which means you have to press the bluetooth sync button at the bottom of the mouse, if it blinks then you can proceed connecting or syncing the device. hit me back with the results.
2helpful
2answers
Dell wireless keyboard and mouse will not work
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Open Questions:
Top Macally Computers & Internet Experts
Paul Bade
Mike
Muzahura Frank
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
