Canon PIXMA iP8500 InkJet Photo Printer Logo
Anonymous Posted on Sep 12, 2012
Spare parts the micro-switch indicating out tray open is broken where can I get replacement
Anonymous
Level 3:
  • Master 622 Answers
  • Posted on Sep 12, 2012
Anonymous
Master
Level 3:
Answers
622
Questions
0
Helped
227221
Points
1525
Try precisionrollers.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Door won't open of Technics SL-CH900
Hi Robert,
probably the cd tray belt (a tiny black rubber belt that connect the tray rack with motor gear) is broken, check this by opening the player, if torn you need to buy a new spare and replace it.
Tray missing error
The "sensor" is most likely a micro-switch. When the tray is in it actuates the switch and closes a circuit indicating to the controller that the tray is in place. Sorry to tell you this but it will have to be disassembled to replace the switch if it has failed as the micro-switches are usually sealed items that are not normally cleaned.
Home theatre system problem: the dc/ dvd part nbot working...the door is continuously opening and closiong automatically.... rest oder things working.. wat is d issue
Check the micro-switches that tell the player when the drawer is fully open, and fully closed.
You most likely have a bad switch, or one that's at least failing.
If there's a nib on the tray that's supposed to hit a switch, and it's broken off, this will cause the same issue.
PRINTER INDICATES " OUT OF PAPER" BUT TRAY IS
Look for sensors or micro switches in tray ins that detects paper load
3helpful
Ptt cant be turn ON
hi,
if you can't feel a clicking sound when you press the PTT button, then most probably that the micro switch under it is either get stuck or broken/damage.
Lucky if it only get stuck and need not to change it. just release again the switch and be cautious cause it is small and can be broken easily. you can open your phone using a t6 screw driver and locate the switch inside. it is tricky to change it if it is broken and need tools, spare parts and the skill to replace it cause it is very small. Have it repair to the nearest service center instead.
Hope I helped you...
Don't forget to rate me OK! Thanks....
rgds,
John
Broken led brackets in the base section, severed wires from monitor to base. Broken keyboard frame and keyboard. Cooling fan (thermal) damaged and heating up. Framework around the dvd enclosure is...
Id have a look on ebay with you model specs for all sorts of spare parts even broken complete pcs,some pcs have good spare part availability but others are difficult to find--good luck!
Davey Snake!
My player opens and closes continuously after switching it on, its only a month old
Here are a few possible fixes :
1. Open the micro switches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.
2. Sometimes the loading belt is at fault. There are microswitches inside which determine the limits of the tray movement. There is one that is activated to indicate that the tray is out and another to indicate that the tray is in. If the belt slips, the inner may not be activated and the system will cause the tray to come out. Try replacing the belt.
We have a Cannon Pixar ip4300 I accidently kicked the paper tray door once when it was open and now everytime we try to use the printer we get an error message about that we need open the paper tray d
I think your on the right track, youv'e probably dislodged or broken a micro switch, screws are mostly underneath, be careful this could turn into a Mecano Nightmare! Good Luck the Yeti
2answers
Karcher K6.50 possible pressure switch problem?
sounds like the unloader is stuck onthe machine which pushes against the micro switch.
follow the instructions for a parts diagram.
www.karcher.com
click on europe
then click on international
go to service and spare parts will open, click spare parts
then put in k6.50m on there will be another number on your machine 8 digit , easy way to find your machine, could 10 different models
Mar 17, 2009 • Garden
2answers
Whirlpool spare parts
with a model number any local dealer should be able to help you
old marine
old marine
ZJ Limited
ZJ Limited
