I would recommend removing all paper trays and opening any hatches that are not screwed down. With this done please check the machine thoroughly and hopefully you will spot the paper in question.
Please bear in mind that even small scraps of paper stuck in the printer can cause this error if they are covering a key sensor.
Once you are confident the offending paper has been removed just closing all doors and replacing the paper trays should make your printer check for paper again (although some models will require you to indicate the jam has been removed).
