Question about Bushnell Optics
Change from meters to yards on bushnell chuck adams rangefinder
Chuck adams archery rangefinder
Kanon Kulpa
First, remove the battery then replace it to reset the unit, then ...
Taken word for word from the manual: While looking through the eyepiece, press and hold the POWER button down for approx. 5 seconds. During this time all liquid crystal segments and icons will be displayed. As you continue to depress(hold down) the power button, the display will toggle back and forth between Yards and Meters. Once the unit of measure desired is displayed, simply release the power button. The device will return to the last unit of measure setting used each time the unit is turned on.
Posted on Sep 13, 2013
4 Related Answers
Anonymous
  • 47 Answers
SOURCE: bushnell quest er6
Here is what I could come up with:
There is no code list available, so check these things:
1) Low battery, replace if necessary
2) You are trying to measure an object that is too close, try a more diatant object
3) You are not holding the rangefinder steady and have not gotten a reading off the target. Try an easier, larger, more reflective target as a check.
4) You have an electrical problem requiring repair.
If you are still getting an error, contact Bushnell at 1-800-221-9035 for instructions.
Posted on Dec 13, 2007
Bruce Frazier
  • 115 Answers
SOURCE: Rangefinder is 4+ seasons old - will not lock-in
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Posted on Mar 24, 2010
Mr Tech Geek
  • 133 Answers
SOURCE: Bushnell Pinseeker 1500 Laser Rangefinder
All these units need an alignment....Vibration and dropping are slow death to Pinseekers.
Posted on Apr 24, 2009
Mr Tech Geek
  • 133 Answers
SOURCE: Meters to Yards
If the unit has a "mode" button, hold it down for at least 5 seconds and see if the "Y" comes up on the screen. Let me know if that helped...mtg
Posted on Apr 11, 2009
I seem to have water or moisture inside my rangefinder. How can I get this fixed or cleaned?
I've dried out meters, etc. before by putting the tiem in a bag of uncooked rice overnight.
How do you make it go back to yards? somehow it got on meters
Step 1: Determine the model of your Bushness rangefinder.
Step 2: Repost your query, being sure to include the information from Step 1.
2answers
Can my bushnell yardage pro rangefinder be calibrated. It is 4 yards off at 30 yards and 7 yards off at 40 yards. So on and so forth
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
Wrong type of measurement showing
On most of the bushnell units you just hold down the MODE button for about 5 seconds and the unit should switch from yards to meters....or vice versa
Meters to Yards
10helpful
How do I change Meters to Yards
with unit on- hold mode button down for five seconds
3helpful
2answers
Bushnell Laser Range Finder
you have it on the meters setting not the yards setting. hold the scan button down for three seconds or longer and it will revert to the other form. a meter is nearly 10% longer than a yard.
6helpful
Acurate distance measuring
hold down the mode button for at least 5 seconds and it will change from meters to yards....or vice versa
Changing Modes
press the power button to turn the unit on then, while looking through the monocular, press and hold the mode button for 5 seconds. You will see the unit of measure indicator switch from meters to yards. Good Luck!
Optics Logo
Top Bushnell Optics Experts
Ekse
john h
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
