I forget log in password of router .at first it was admin but i changed it n forget.help me
Just hard reset your router
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router. After a hard reset, every router returns to default factory settings.
See: how to perform hard reset
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
SOURCE: Router login
If your Comtrend CT-5621 came with the package from your ISP then it is possible that the username and password has been changed by your provider and you would have to get in touch with them.
In some instances the username is "root" and the password is "root".
Some known passwords from ISPs are:
Canadian Broadband/Aliant - RM60008
NetComm - NetC0mmV3oo
Some ISPs disabled/blocked the web based configuration interface and the initial way to communicate with it is a telnet session to the router.
Would you know if your default IP address of 10.0.0.1?
Good luck and kind regards.
SOURCE: forgot passwrd on a us robotics router
Generally you have to push and hold the reset button, i suggest for 30 seconds, this should completely reset the unit, including passwords and settings.
SOURCE: i can't log in my router to config it..
its not actually a problem, all u have to do is to manually restart ur router and try again with the user name admin and with the password 123456 or 1234. hope it solves ur problem.
SOURCE: DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
SOURCE: sbg900 router, login problem
try to configure the browser settings, follow the steps below
1. Go to internet options and select the security tab
2. Highlight Internet and click customer level button
3. Scroll down to the very bottom, under user authentication select automatic logon with username and password
4.rest customer settings to medium
