check the wire in the power switch , maybe the power switch got stucked , remove the socket in the power switch , and go manualy switch on with the screw dricer
pull out on the headlight switch to manually turn the lights on and push it back in to shut off to override the automatic feature. I do this on my own at times
Have you tried powering the brak circuit itself at bulb. If it comes on then you need to find broken wire between light and switches. Since neither work if you can trace to where they meet break should be behind that.
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
The compressor coming on when the contact is pushed is o.k. they all do that. As for the blower fan not shutting off, some brands (Payne for example) the heating fan relay is a n.c. (normally closed ) relay. so if the time delay relay or thermal link are bad or not connected, the fan will blow even when it is turned off.
