Question about Kenmore Freezers
Freezer won't turn on
My freezer was working fine until I defrosted it. I plugged it back in and tried to turn the knob to any level and all it does is click and hum and then the hum goes away. Then after 8-10 seconds it clicks again and hums. Kenmore model 253.9234113
Posted by Connie Cwynar on
Jude Laurence
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Posted on Sep 12, 2012
  • Dawn Moore Jan 02, 2020
    How long do you have to wait? I am having the same problem and we defrosted it yesterday.
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Posted on Mar 19, 2007
Anonymous
  • 149 Answers
SOURCE: Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail [email protected]
Posted on Jun 08, 2008
douglas smith
  • 1462 Answers
SOURCE: freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Posted on Sep 07, 2008
Anonymous
  • 999 Answers
SOURCE: compressor click
Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
Eric
Posted on Jan 24, 2010
Anonymous
  • 4793 Answers
SOURCE: Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Posted on Feb 06, 2010
GE UPRIGHT FREEZER NOT FREEZING.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
You are locked in the defrost mode. About every 8-10 hours your freezer will go into a defrost mode for 20-30 minutes. This is where all of the components will shut down except for the light.
You have water on the floor because your condenser fan and compressor is shut down.
You did not provide a model number. Your model number is on the inside wall of your freezer near the top. So, I can only guess.
Lets take your freezer out of the defrost mode. In the lower back on the left hand side is your defrost timer (This may also be in the lower front depending on the model). Following is a picture of what a defrost timer looks like.
The time is mounted on the back of a plate and held on with two screws. The plate has a hole through it to give you access to the round knob on the left. The knob has a slot in it. With a flat head screw driver turn the knob clockwise. You will hear a click. Turn one click at a time until the freezer turns on.
The timer cost about $20.00. You can replace it yourself. Unplug the freezer. Unscrew the timer. Remove the connector on the right.
You need to replace the timer or you will have icing problems.
Send me your model number and I will tell you what the part number is.
Defrosted my Frigidaire freezer plugged it back in but it won't turn on
Give it a while it might be in defrost mode. If it does not cone on after an hour I would check the defrost timer. Most of these are on the base of the freezer in front behind the kick panel. You can manually advance the timer like I did in this video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Defrosted now won't turn back on
blower motor may be bad..it activates the fan in freezer
2helpful
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
I have a 20 cf upright GE freezer that isn't
it may be froze up, and require a defrosting. use a portable fan to speed up this process , also make sure the fan in the freezer compartment is working, with a little work and a zoom spout oiler, or some light motor oil, the motor can be sparked back to life.. freeze ups are common with the high humidity we are having these days.. jay the pool pump motor repair guy longwood Florida
Aug 02, 2011 • GE Freezers
2answers
We have a true single door freezer, it is iced up inside . what should the dial inside the unit be set on.
On the freezers a setting of 7 or 8 should do fine. I would be more concerned with the defrost timer, defrost heater, and settings. Also a HUGE problem is that the door switch on the top center of the door can sometimes barely contact the door (this happens when a unit is slightly warped or out of level) or the spring loaded hinge on the door can break causing the door to stay propped open at times. When the door doesn't close the evaporator fan stops but the compressor will continue to run. I have had to tape a nickel on top of the door to make better contact with the switch. Make sure the switch isn't the problem before going any further.
The alarm went off indicating that it the temperature had risen above the recommended level for keeping food frozen and safe. However, the temperature knob is set to the highest possible level.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Freezer door not sealing
Probably a defective defrost timer. Try to find the timer. It is usually underneat in the back. When you find it turn the knob slowly click by click. (You may need a screwdriver or knife) turn just until the compressor stops. Let it stay in defrost for about 1/2 hour. turn the knob until the compressor starts let it cool down several hours. Then do it again. If this solves the problem replace the timer. While you are waiting to do this Defrost it at least twice a day by turning the knob.
Jun 30, 2008 • Freezers
2answers
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Freezers Logo
Top Kenmore Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
