Is there a way to play this DVD on a computer monitor?
I am using this player at an convention and need to connect it to a computer monitor.
Posted by Loree on
Anonymous
  • 32,281 Answers
MP3 players connects to a computer using an USB cable.
When connected the computer will see the MP3 player as an external storage device.
This allows you to copy files from the computer to the MP3 player and it will also allow the computer to read files off the MP3 player. Therefore you can select and play video files from the MP3 player on your computer monitor.
Posted on Sep 12, 2012
Can i connect a dvd player on it
only if your dvd player uses dsub or dvi connections. so prob not.
(ive never seen it) dsub and dvi are comouter connections.
youll need a dvd player and monitor with the same ports.
hdmi or svideo are you most likely options (depending on what port the dvd player has. it may only use RCA which is rare on computer stuff)
DVD Player Won't work
Hi have you used this dvd player before or is this the first time.
Also is it saying format not suppoted when you try playing the dvd.
Please give me this info then i should be able to help you further ok
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
How do I hook up blue ray to hannspree
You need to put a bluray DVD player in the computer connected to the monitor in order to play a bluray DVD on the computer. Monitors are NOT TV's so there is no direct connection possible.
1helpful
Driver for LG 1511s monitor
The DVD player should automatically put the signal out on the component terminals, and probably also on composite and S-video. There may be selector buttons on the front of the player for that purpose. (I'm assuming this is a DVD player unit, not a program in a computer.) No driver should be needed; it's hard-wired.
The big problem is that the monitor has only a VGA connector for computers and cannot be connected to a common DVD player without a composite/component to VGA adapter (very hard to find). The surest way you can get a DVD signal to it is to play it in a computer with a DVD player program and DVD drive. No separate driver is needed; the DVD player program and the computer's graphics driver take care of it.
Hi! Just want to ask how can I connect my viewsonic monitor from computer to dvd player?
Get an adaptor, you don't say what model of monitor you have so I can't be more specific, You will probably also need speakers from the DVD player to get sound and an amplifier and the correct leads. But why bother? if you want to watch DVDs on your monitor then play them on your computer.
3answers
Can i play an iso file in my standalone dvd player
No. You can't play .iso files in any standalone DVD player.
PC flat screen monitor to DVD player hook-up
It appears that the monitor was designed to work with the display circuits and software driver on a Personal Computer. There is no circuitry in the display to handle the out put of DVD player. A smart TV has the circuitry. the display does not.
4helpful
2answers
Progressive Scan
On 12/29/2007 at 1135pm, I found the solution for yours and my problem. Here is what you need to do. I did the same thing and couldnt get video. If you set Progressive Scan to ON in error , you must reset the unit. Play your dvd, then press "STOP" to stop the disc from playing. Hold the stop button on the dvd player for approx 5 seconds before releasing it. The video output will be restored to the standard setting, and a picture will once again be visible on a conventional analog TV or monitor.
Marvin
Marvin
