Here is blink codes for HP and Compaq's before and after 2015
http://support.hp.com/us-en/document/c01732674#AbT2
the seond set of blink codes is the one you need.
SOURCE: how do i remove the outer bezel on a compaq
1. Take the side door off as usual.
2. Locate the drive door lock inside the chassis.
3. Rotate the lock to the down position to unlock the upper front panel door.
4. Press the indentation located on the lower front panel to open the lower door.
5. Grasp under the bottom of the upper front panel door, lift up, and gently remove from the hooks. (Tip: The upper front panel door has finger holes.)
6. Remove any of the bay components by pressing both sides of the drive rails. There are no screws.
hope this helps...........
SOURCE: driver for cq61-300sv
here is the link for drvers for this notebook.
http://h10025.www1.hp.com/ewfrf/wc/product?product=4093994&lc=en&cc=us&dlc=en&lang=en&cc=us
click on software and driver downloads
SOURCE: I have a Compaq presario
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The
LCD cable transfers data signal from the motherboard & video card
to the LCD screen. It also supplies high voltage DC power to the screen
inverter board. The screen inverter board works as a power supply for
the backlight lamp mounted inside the LCD screen. It converts low
voltage DC power to high voltage AC power needed for the backlight lamp.
SOURCE: COMPAQ PRESARIO CQ61 MOUSE FREEZED HOW DO I SOLVE
hey! i think u need to troubleshoot ur hardware device manager for mouse and have to clean up ur registry with reginout cleaner
SOURCE: compaq presario cq61 showing battery
Charge your battery, it's empty. If you get this message even after you have charged it then the battery has aged and it can no longer hold its charge so you must replace it.
