Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
These lines run from the top of the page to the bottom and are about 1'' to 1 1/2' on both sides. I went through the manual the did the procedure to clean the document scanning area and the procedure to clean the print roller. This did not help. Please help.
SOURCE: Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Posted on May 27, 2008
SOURCE: Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Posted on Jul 18, 2008
SOURCE: panafax 550 leaving heavey black lines on pages
Clean the optical area with a soft cotton piece of cloth and window cleaner. How does the cartrige looks like, if you see toner on the drum you may consider replacing the cleaning bladeand the drum if necessary. The cartridge was refilled?
Posted on Oct 14, 2008
SOURCE: Panafax UF-880 - volume of phone ringer
1- incoming volume press the down arrow till you want the desired level
2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
Posted on Dec 09, 2008
SOURCE: trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Posted on Jan 14, 2009
May 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Feb 25, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Oct 08, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Jun 09, 2009 | Panasonic PANAFAX UF-6000 Fax
Apr 21, 2009 | Panasonic Office Equipment & Supplies
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Oct 30, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Oct 14, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Jun 04, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
52 people viewed this question
