The 3 led lights are flashing on the front of the set. the owners manual says to replace the bulb
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
SOURCE: Very noisy when turned on, then shuts down, Samsung 61 inch
That certainoy sounds like the color wheel assembly inside of the light engine is bad. The light engine is located here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00674A&search%5Fmodel=HLP4663W Good Luck
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
I have the exact same problem, TV stared doing it about 12 days ago, I ordered and replaced the Lamp, it still does the same thing...
""Lamp" light flashes for 20 seconds and then you hear PS clicking,
repeats cycle 3 times before it shuts off and all 3 lamps flash!"
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
SOURCE: Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
