The colour red is not displaying, despite the fact that I have just replaced the lamp
SOURCE: lcd projector beeps every minute
Hi Jenrowe
Try resetting the lamp and filter timer , if this still occurs reset the whole mashine.
SOURCE: Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
SOURCE: My Hitachi CP-X201 has a flashing red lamp light
Hello :
Did you replace the lamp correctly ? If not , then i'll tell you how to do that :
Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
I hope this will help .
rate please !
If that wasn't helpful , then contact again please !
SOURCE: My Hitachi CP-X275 Multimedia Projector
Normally when a unit like this shuts down, there are indicators that will show why. Are any of the lights on or blinking when this happens? The most common cause is overheating. Is the lamp indicator RED or the temp indicator? A little more detail would be helpful here. Can you also indicate how long the unit runs before shutting down?
Thanks,
Dan
SOURCE: Dear Support, We have HITACHI LCD
Hi
--- Please dont forget to vote this answer was helpful. Many thanks ------
sounds like the bulb has failed.
Recheck the connections of the bulb in its holder but failing that you will need to buy a new bulb.
Probably overheated. Turn off the power and wait for the machine to cool. Then check that the filters are clean and that nothing is blocking air flow - and that fans are running. Turn it back on. If the same thing happens, they say to replace the lamp. I would check the number of hours on the lamp - it may be nearing end of life. Hopefully, it is a ventilation problem.
