Beautiful shaped electronic clock approx 9 years old. Just stopped, new batteries not correct fault. Love clock and want it working please. We have done nothing at all to it except look at the time.
Your clock is not a sewing machine.
Sarcasm is not an attractive trait!!!! The question was put in the wrong section!!!!
I did not display sarcasm.. I simply stated that a clock is not a sewing machine. As far as attractive traits... Ignorance isn't an attractive trait either. Remember while you are pointing the finger at me calling me sarcastic... 3 others are point back at yourself.
Oh dear, no idea where you gai ed the "ignorance" comment, you sound soooo aggressive. Delighted you are not an acquaintance of mine.NEVER a friend. No reply necessary as contact with website cancelled!!!!
SOURCE: needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
SOURCE: BerninaMatic 910 Electronic machine. The foot control has broken
Bernina foot controls cost a fortune, have a look on ebay you find someone selling spares, other than that it will mean going to a Bernina dealer
SOURCE: juki 5550 - SC 800 with electronic display - it
E13 is appearing on the panel of sc 800 control box
no such error is listed on the instruction manual please advise
SOURCE: I have a White Speedy-lock model 234DE that is
Yikes, it does sound like it was knocked out of alignment. You have made sure all tension adjustments are right, correct? Hmmm there is not a whole lot else you can check. I would try that left needle to see if it winds correctly. If it does you know something was knocked off on that right needle. It may need to be professionally serviced at this point, it sounds like you have done all possible simple things that you can check...
Let me know what you find with that left needle and I will continue to research this.
Thanks,
Tim
