In most cases, you startup your PC with a disc (CD or DVD) containing the OS. (OS=Operating System)
You may need to "enter the BIOS" to make sure that your PC starts from the disc. To do this, restart your computer, and press the F10 button while it starts, then select bootup sequence, select disc drive. If that doesn't work, you might need to press a different F-key, your PC should tell you, at the beginning of startup, "press F8 for advanced startup options" or something similar. Press that F-key instead.
If you want all your questions answered, I think you should enrol on a course at a college.
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google: ipaq+6515+sdio+card
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
