Question about HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576)
M2N78-LA beep code - HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576)
1 Related Answer
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: The drives are not recognized
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS
hope this will help
Posted on Jul 26, 2011
Tip
Why choose HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E??
Things to be considered in choosing HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E
1. Processor and Memory upgraded
3. I/O Ports and Network
5. Clearing BIOS password
For details you can visit web site www.hpparts.us
on Apr 02, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Short beep long beep
You have a Memory (Ram) problem. Follow this it may help.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=3440615&docname=bph07107
Apr 09, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
HP Pegatron M2N78-LA having trouble finding a replacement for my motherboard with the same part number, would i be able to put a HP Pegatron M2N78-LA with a different part number into my machine
Before you give up check on ebay. If you do replace just make sure that the physical size is the same and that the replacement uses the same cpu and memory you have now. Otherwise you will be spending much more dinero.
Apr 01, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Pegatron M2N68-LA
they are number one on the cables are red
Feb 28, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
E241819 cl
go to hp support download bios from there ok.
Nov 02, 2013 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
What is a compatible replacement for a m2n78-la motherboard
This motherboard's full name is ASUS M2N78-LA and also used from HP/Compaq with the name: Viola-GL8E. A good replacement solution for this board is Zotac GF8200-C-E GeForce 8200-ITX WiFi AM2 DDR2-1066 (about 130$). Here are some links for this board: from Nvidia for specs and from Amazon. Take care that the original board is micro ATX factor and the suggested one is ATX factor, so you may have to check the available space in the tower.
Stelios
Oct 22, 2011 | Computers & Internet
HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576) Logo
180 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
