Question about Fuji FinePix V10 Digital Camera
Zoom error finepix v10 - Fuji FinePix V10 Digital Camera
Posted by Dennis Smith on
Jude Laurence
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
You need to refer to it manual in section lens adjustment.
Posted on Sep 11, 2012
5 Related Answers
Anonymous
SOURCE: Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Posted on Mar 26, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Zoom Error on FinePix 2800
just take the battery out leave it for 10 minutes and put it back the battery.push hold power button for 10 seconds,then try to checked is ZOOM ERROR is gone if not go to menu button and set it for factory default or reset..try this option maybe can help.
Posted on Jun 24, 2008
lock123
Andrea Lock
  • 6831 Answers
SOURCE: finepix s2000hd zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: Fuji FinePix A345Lens cover does
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 12, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: fuji finepix f650 zoom lens
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Posted on Nov 20, 2010
1helpful
I have a fujifilm digital camera its a finepixv10 i plugged the wrong charger into it now it will not turn on , can you help ?
As you have used wrong charger so you have to see if the problem is withe the camera or FUJIFILM FinePix V10 Zoom battery, Or if the battery haven't been charged by the charger, so the power is empty and you can't turn on camera, Then use a right FinePix V10 Zoom battery charger..
Apr 26, 2011 • Cameras
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
2helpful
I have got a zoom error on my fuji Finepix V10. When you turn the camera on the zoom starts to come out and then quickly retracts. How can I fix it?
Sounds like the timing for the sensors on the lens are out and will need to be reset.
lens unit will need to be removed and reset
Zoom error
It appears that the moving parts of the objective(those that go in and out when you zoom) could be damaged.This occures when the camera is dropped-in this case the most you can do is cleaning the moving parts and try gently to shake them or do anything that may unblock it.
Another blame could be the weak batteries or acumulator of your camera.Try get some new batteries or charge the acumulator.
A final thing you could do is reset to default the camera settings.
If any of these won't help, I suggest you should go to a specialised service, cause the problem-more common than you think- could be serious.
Good luck Smitty
TigerFly
Fuji FinePix V10 Focus Error
Hello
Regards
Andrea
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
3helpful
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
2helpful
2answers
Fuji FinePix S7000 Digital... Problem: Zoom Error
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Card Error
http://www.ecamm.com/mac/cardraider/ might recover your files. Still need solution for card bad format. Same problem here...
Fuji FinePix V10 Digital Camera Logo
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
