Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
I want to connect SP0802N HDD to laptop with usb
2 Related Answers
Anonymous
  • 679 Answers
SOURCE: JUMPER SETTING
to make a HDD as slave, put off the jumper out.
for any question ask me.
Thanks for your question.
Posted on Jan 03, 2009
Anonymous
  • 1383 Answers
SOURCE: HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Posted on Aug 01, 2009
How do you take a internal Samsung SP0802N and set the pins to make it an external backup HDD HDD
well u dont have to do anything with the pins my friend there is a casing available in the market for sata as well as ide by which u can use an internal hdd as an external .... u can get it from a local computer shop
Feb 08, 2011 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
It is very slow, is not in DMA mode
if you have xp :device manager-ide ata/atapi controller-select your hdd controller-properties-advance sttings-see if are dma available, if not set it.
Apr 19, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
The HDD is in a Mobile Disk external package. The external power supply is dead. I need the specs for a power supply ( voltage, current).
This will resolve your issue,
http://www.samsung.com/ph/consumer/monitor-peripherals-printer/hard-disk-drive/35-pata-hdd/SP0802N/index.idx?pagetype=prd_detail&tab=spec&fullspec=F
please remember to vote right if my recommendation resolves your problem,
regards
Mar 24, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
It need repairing .
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung sp0802n HDD enclosure. I installed everything. The safe remove program detect the massage storage, but the hard drive icon does not show.
Has the hard drive been formated?
To format the drive, plug the external drive into the USB port - go to the Control Panel - Administrative Tools - Computer Management - Storage - Disk Management. The External drive should be listed as USB drive. On the lower panel, right click on the USB Drive and click on Format, and format it in NTFS.
After formating you will be able to use it as a normal hard drive.
Hard disk Warranty
Contact Samsung
Model: Samsung Spinpoint SP0802N
Call 1-800-SAMSUNG (1-800-726-7864)
Jan 10, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung SP0802N External Case?
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Dec 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
JUMPER SETTING
Aug 31, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
My Samsung HDD SP0802N 80 GB PATA says read error and not booting
dear suresh
just trying using hdd utility like partition magic or with disk management in window
but i supposed to fixed it in another pc , you can partition it with two or three partition
after that youcan format it
oke
cropp
Mar 18, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
