Full water in dispenser runs like it is working then turns self off. auto off turned off.
SOURCE: keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
SOURCE: My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
SOURCE: my keurig model b66 coffee maker is not dispensing
Run the descaling operation as described in the manual. If this doesn't do the trick, get a can of compressed air with a nozzle on it and blow the air into the upper nozzle, the one that pierces the cup on top. This works when the descaling isn't the problem.
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
