Question about Samsung Refrigerators
I have a Samsung RF266 and the control panel is not responding. The power cool is flashing and making a dinging sound. The temp. keeps dropping and none of the buttons are working.
The freezer seems fine it just the refrigerator part. Its the french doors model.
peter angrave
I have been having the same trouble for over a year and my wife is ready to throw the dinging thing out in the backyard. This is not the only issue with this refrigerator as it continuously ices up at the back and I have to defrost it every few months. So waiting for a sale on an LG.
Posted on Jan 11, 2022
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Anonymous
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
Anonymous
SOURCE: Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Posted on Oct 13, 2008
Anonymous
  • 700 Answers
SOURCE: SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Posted on Jan 01, 2009
Anonymous
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine. After pressing the ice maker reset button, I hear a ding don sound coming from the control...
It won't harvest ice on its own unless it detects a temperature of 10 degrees. The ding ding sound is the control letting you know that the ice maker is functioning fine. Remove the evaporator cover in the freezer and make sure the coil isn't frozen over and the fan isn't restricted from turning. Check the door gasket is getting a good seal. If that's all good replace the sensor on the ceiling of the freezer.
My samsung frige, french doors keeo ringing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
1helpful
2004 Caravan temp light and rapid dinging
If you have a problem with a light check your temp gauge. Chrysler warning on engine overheating responds that way and as the engine becomes hotter the chime becomes more rapid. Check your antifreeze and fluid level, this may be the problem.
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
Refrigerators Logo
Top Samsung Refrigerators Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
