The covere is closed but it still says 1. Close front cover I've tried turning on/off, unplugging, & opening & closing the front cover, as well as, the other doors to no avail.
SOURCE: Copier Error Message
Their's a sensor that the Plug from the Finisher to the copier is not read, first make sure the "Attachment Kit' thats the part where when you push the Finisher to the Copier it Locks, their is a metal tab that sticks out and hits a "Sensor" if it doesn't hit the sensor it will keep telling you attach finsiher or close cover, if it's too annoying you can remove the finisher and unplug it from the rear. On the cover thier are alos sensors that need to be activated by tabs,MAKE SURE these are not missing if you do you need to order these items from "Koycera-Mita" Check those sensors
SOURCE: KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
1.
Make sure the printer is on.
2.
Open the printer cover. The print cartridge carrier moves and stops at the
loading position, unless the All-in-One is busy.
3.
Remove both cartridges from the carrier.
4.
Close the printer cover.
5.
Unplug and re-plug the printer into the power outlet to reset it.
6.
When the printer turns on, reinsert one cartridge first.
7.
Close the printer cover and check for any errors.
8.
If no error appears, reinsert the other cartridge. Close the printer cover.
9.
Replace whichever cartridge is causing the error to appear with a new
cartridge. You may also try to insert a different known working cartridge to determine if the cartridge you are currently using is faulty.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
