SOURCE: fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
SOURCE: talkabouts not communicating
What you have described is typical of the radios not being on the same frequency and/or code. If you know how to put your radios in programming mode, set all the frequencies and codes to the same number, then they will work together. If you still have the owners manual it will describe this process. Usually with a TalkAbout radio it consists of holding in the PTT while turning the radio on.
As you are probably aware, the radio will have approx. 14 frequencies installed. You can usually select these easily from the front panel. The second number you see in the corner of the screen when you turn on the radio is the "code". This is an interference eliminator. All of your radios need to be set to the same code to work correctly together. If you find one or more of your radios does not have "code", simply set those that have "code" to zero.
