Question about Microsoft Windows Vista Home Basic Edition Full Version for PC
I am tryign to uninstall fix it, get error 5006
I am trying to uninstall Fix it by Avanquest, I am using the uninstall program tool in Conrtol panel, I click on uninstall, then it starts and I get this following message, Error Code: 5006 : 0x80070002
Posted by dianecoll352 on
Brian Sullivan
  • Microsoft Master
  • 27,725 Answers
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Posted on Sep 11, 2012
5 Related Answers
Anonymous
SOURCE: cannot find regsvr.exe
it showing the same problem as i installed the Regsvr.exe file in System32. it showing file missing on or corrected...... can u get from this .
Posted on Mar 15, 2009
ipodslinger
Steve Brown
  • 688 Answers
SOURCE: cannot delete ESET folder from Program files. the
Apparently MS in their infinite wisdom decided that in vista they would take the power away from the user and remove the administrator from the equation.
So no matter how many thing your try in the user accounts you will not get full admin rights.
but here is a reg hack that worked for me real well. I am running windows vista home basic
Click Start and Run type in regedit and enter
your now at the registry editor.
click and expand HKEYLOCALMACHINE
go down and click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENTVERSION
click POLICIES
click SYSTEM
you will see the registry entries to the right
right click in the white area and select new DWORD
Name it "EnableLinkedConnections" and enter
Right Click on EnableLinkedConnections and choose MODIFY change the Data Value to "1"
Save and exit Registry Editor
Reboot your computer and try deleting the folder you wanted to again.
WARNING:
Using this reg edit you are changing your registry and could develop problems if you don't do it correctly. Be Warned and do some research prior if you need to understand registry editor.
Posted on Jun 04, 2009
Anonymous
  • 68 Answers
SOURCE: MS Office 2007 Professional won't install on my Laptop with XP
yor ms office 2007 cd or dump is corrupt pls try another one
Posted on Jun 24, 2009
Anonymous
SOURCE: Explorer.exe Application error in Windows XP Professional SP2
i think you must to format it with the good cd windows because the problem is has an error while installing windows. thx
Posted on Sep 19, 2009
disyl14
  • 7 Answers
SOURCE: Fatal Error: Loading module SGEDRV.dll failed (Error #126).
Right Click om "My Computer" and select Properties | Advance Tab | Environment Variables.
Select Path Variable in the lower part of the box by clicking on it and add C:\Program Files\Utimaco\Safeguard Easy
Note: To insert ; (semi colon symbol) after the previous path
Thank you
Dion S
Posted on Nov 06, 2009
My yahoo massenger did not open
Try uninstalling the program from the conrtol panel and download and re-install the program. That should fix it.
Apr 03, 2011 | Yahoo Messenger
How do I uninstall Avanquest Fix-it 10 Utilities Professional? I have attempted to uninstall via Control panel; Programs and features; Uninstall or change a program (Vista) but Avanquest/Fix-t does not...
You can try these options
1. Boot the computer to safe mode then browse to C:Program files\Avanquest\ rename "the Fix it folder" to OLD reboot then delete the OLD folder. Then run a registry cleaner to clean out the craps.
2. Use "IObit Uninstaller Free Advanced Uninstaller Software" to uninstall it.
Hope it helps.
Oct 25, 2010 | Avanquest Fix-It Utilities 10...
HOW CAN I UNISTALL FIX IT 9?
This came from the Avanquest Forum.
You can uninstall using the Add or Remove Programs component in the Windows Control Panel. This will initialize the Windows Installer to assist you with uninstalling.
If SystemSuite or Fix-It is not listed on the Add or Remove Programs list you can remove the program using the MicroSoft Installer CleanUp Utility. Please go to the following page and follow the steps on the web site. Run the utility and see if it detects SystemSuite or Fix-It and if it does then delete the entry. Once you've done this check the install directory located at C:Program FilesOntrackSystemSuite or Fix-It or VCOMSystemSuite or Fix-It and delete the folder if it still exists.
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Best of luck getting this removed...I've read many reviews and people really dont' like it too much.
Aug 20, 2010 | Avanquest Fix-It Utilities 9 Professional...
How to uninstall Fix-It Utillities 10 Professional from my computer [email protected]
Hello there!
Go to
1.Start
2.Control Panel
3.Add or remove program
4.Select the program
5.Click uninstall.
Hope this helps!
May 12, 2010 | Avanquest Fix-It Utilities 10...
Uninstall not working for System Suite 9 on Vista 64 bit system
I had a similar problem with a different program a while back. I came across Revo Uninstaller and found it very useful to fix my problem. Try download.com for the free version, see if it helps.
Apr 18, 2010 | Avanquest System Suite 9 Professional Full...
I've downloaded Fix-it 10. It won't install until
Well in that case go to the Program Dir find the Folder it is in, and simply Delete the files, delete them all, then remove delete that Dir, Now try a reinstall. Either that or in that Directory look for the uninstall exe file and double click on that and try that way first... else remove them all.
Feb 19, 2010 | Avanquest Fix-It Utilities 9 Professional...
Tried everything to uninstall Avanquest Fit-It
Go into the the Program Files directory of your C drive. Look for Avanquest or Fix-It directory. Look for unwise.exe or uninstall.exe or something similar. Double click that and follow the prompts. If that doesn't work, please let me know and I'll do some more research.
Feb 16, 2010 | Avanquest Fix-It Utilities 9 Professional...
How do i remove avanquest fix it
When the question is so specific, for sure, the user is not being able to remove it using the control panel. It would be great to ASK if they already tried such SIMPLE solution. Fix-it is a pain to be removed, specially the version 10 that won't be removed even with the Revo uninstaller! I'm working on 2 computers to remove this piece of s....ware and will post any solution I find for it.
Nov 27, 2009 | Avanquest Fix-It Utilities 8 Professional:...
Avanquest system suite 9
Bring up Internet Explorer, click on tools, click manage add ons, click enable/ disable add ons, look at enabled add ons, disable Data Vault. Restart your computer. This will fix your script errors with System Suite 9 on Internet Explorer.
Oct 26, 2008 | Dell Inspiron 6000 Notebook
Microsoft Windows Vista Home Basic Edition Full Version for PC Logo
193 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
