I have a Fresh Air 2. My serial number is 198241
SOURCE: Fresh air 2.0: Unit cycles on and off.
The problem is dust or moisture on one or more of the circuit boards, in the bottom of the unit. The problem is usually caused by resetting the cleaning reminder without actually cleaning the machine. ;-) It hasn't been difficult for me to solve so far. Remove the filter. Remove the two screws that hold on the plate where the rear switch is located. The wires are long enough that they don't need to be removed from the switch. Use a blow dryer or dry compressed air to blow off the circuit boards. ****Keep your face out of the way!!! Be sure not to get the blow dryer too close or too hot. If you have a Warm setting, use that. Good luck!
