Question about Microwave Ovens
Can not locate the light bulb in my LG microwave oven model MC-9243JLRZ
Light bulb is burned
Posted by emad2191 on
jeff rollins
    Sergeant:
  • 239 Answers
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
THENTHEREWER
Terry Rodgers Jr.
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Jun 26, 2009 | GE Microwave Ovens
MICROWAVE LG MODEL MC-806BL LAMP BLOWN
In the UK, LG customer support is here. You may find your owner's manual online here.
Dec 19, 2008 | Microwave Ovens
Majic Chef cabinet mounted microwave oven model VM11B-8P
On the electronic control board, the circuit trace will open like a fuse if the light bulb power becomes shorted. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for a burned, open circuit trace.
4. Repair circuit trace everything should work again....
Jun 15, 2008 | KitchenAid KCMS145J Microwave Oven
Light bulb burns hole in the plastic cover
Same issue here. I just bought 4 covers from RepairClinic.com for $5.50 US each. I shipped them to my PO Box in Buffalo for an extra $6 bucks. Part number was 1206433
Hope this helps
John
Dec 23, 2007 | LG LMVM1945 Microwave Oven
Microwave Ovens Logo
248 people viewed this question
Top Microwave Ovens Experts
Marvin
Marvin
acmservice
Are you a Microwave Oven Expert? Answer questions, earn points and help others
