I have a Zerox Workcentre 6505 DN which is printing horizontal coloured lines on every page it prints. Any ideas? The lines are different colours (yellow, green, cyan) on one set. Then different colours again (Magenta, Purple, Black) on the next set. These sets of lines appear throughout the page with a 9mm gap between the sets.
SOURCE: My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
SOURCE: Xerox DocuColor 4CP printer will not print colour.
SNMP Printer Management Information Block. Note that actual support varies by device. .... Tektronix Phaser 850. HP Color LaserJet 9500n. Xerox DocuColor 4CP ... Extended Print and Print Server features have been exposed for Lexmark devices. ..... because the OK button will not be enabled until a valid value is ...
www.lexmark.com/publications/...2/MVP_11_2_Release_Notes.pdf
I also have the above problem
