Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Speakers bose docking station make a noise
Also I have problems with the volume buttons. If I push one time on the + button, it goes fom very low to very high. Bought a couple of years ago, two new remotes and they both did not work for my "old " one. Can live with that. Always took care for my sounddock, still looks new and clean, always loves Bose items and have emotional problems to throw this one in the garbage bin.
Posted by Suzan van Doorn on
Suzan van Doorn
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Posted on Sep 15, 2012
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Posted on Dec 11, 2008
Anonymous
  • 71 Answers
SOURCE: does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
Posted on Jun 01, 2009
Anonymous
  • 8 Answers
SOURCE: bose docking station problem. Remote will not work
If it is brand new. It is under warranty. Go back to the store where it was purchased and tell them the problem. They should replace it with another new one. Have them show you how to use it on all of the functions on your Bose Docking Station. Make sure you tell them about the ipod Touch and the iPhone.
Posted on Jun 10, 2009
Anonymous
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Posted on Dec 03, 2009
Anonymous
SOURCE: Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Posted on May 25, 2010
Where do I get my SoundDock fixed?
It could also be that the volume button has gotten stuck, misaligned and it needs to be seated back into the the right spot. If you feel comfortable in removing the bottom of the Dock connector held on by three screws, you could look and see if the volume button is stuck or maybe a little crooked. I don't believe that this is caused by a bad circuit board. If you have experienced any problems with the docking of iDevice, I would check out www.invebo.com and make sure to type in the www. For some reason it will not navigate to the website if omitted. They are an awesome company for Bose SoundDock DIY repairs or have them repair it for you. Check out the Bluetooth upgrade, if you have an iPod Touch or any device with Bluetooth, you don't have to dock the device anymore. So you have more control of what you're listening to. Anyway, I bet it's just the volume up button that is stuck, or something is stuck in the volume up bottom on the right side of dock connector. If that is not the case then INVEBO is the least expensive repair route, under 50 bucks., Bose will do an upgrade, switch out program, running you a total of around $164.00. You send them your unit, they send you a box for the return, then they send out a new unit.
May 11, 2014 | Bose SoundDock® (Black) Docking Station...
Try to adjust the volume(on dock only) and just keeps getting louder havt to pull ipod
Volume button stuck in. Try and free the button as it may be jammed. It may need to be taken apart to loosen the up volume button. First try prying it up externally but be careful not to break anything in the process.
Sep 21, 2012 | Bose SoundDock digital music system...
Hi, i have an apple i pod docking station Model A1121. It doe'snt want to play whenever an ipod is attached to it. The lights are all on and flash when pushing the volume button, buut no noise.
my mail id : [email protected]
May 20, 2010 | JBL On Time Docking Station for Apple iPod...
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
My bose ipod speakers are making a knocking noise and not charging my ipod
bose ipod speaker been turned of for a few months just plugged it in making a knocking noise is this normal
Jul 11, 2009 | Bose SoundDock® (Black) Docking Station...
Bose docking station problem. Remote will not work on either my ipod touch or I Phone. The volume buttons work on the remote but the skip and pause/play buttons do not. The Bose is brand new and straight...
Jun 07, 2009 | Bose SoundDock digital music system...
I have an ipod touch 8G I purchased a Bose soundock II. The sound is great but the remote only controls the volume. I cannot change tracks, move through playlists and when I hit the off button on the Bose...
Bothe the docking station and the remote are useless I recommend you buy a universal remote control.For the Ipod switching off-it does'nt switch off reason being it has it's own battery and does not depend on the electrical power of the docking station.
Mar 06, 2009 | Apple Bose SoundDock Series II Digital...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
302 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
