Question about LG 42CS560 42 Class LCD HDTV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
My tv won't get out of standby mode. When it is plugged in, the red light is on so I know it is getting power. When I press the power button on the remote, or try turning it on from the tv itself, nothing happens. I just bought this TV a few weeks ago and have done nothing out of the ordinary with it.
    Top Expert:
  • LG Master
  • 55,370 Answers
Could be an open internal fuse or power supply failure
Posted on Jan 05, 2018
5 Suggested Answers
6ya staff
SOURCE:
tvtek
Duke
  • 1284 Answers
SOURCE: LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Posted on Nov 30, 2007
Anonymous
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
rtb2000
SOURCE: lg 50pq3000-za plasma tv will not switch on from
power problem possible fried power capacitors
possible cause power surge could occur if unplug while tv on
must change 6 power capacitors
these original capacitors are on the low end minimal ratings
1-2 hours in house labor, cost est $200 plus minus
Posted on Jul 09, 2010
russell abbott
SOURCE: TV always in standby mode and can't display channel. Need press many times
Go to Badcaps forum online
Posted on Dec 07, 2011
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
I have a 52LG70 that won't turn on out of standby mode. When the TV is turned on the indicator changes from red to blue but there is no picture. No menus or settings are displayed. When I unplug t
If you are able I would suggest taking back off and "looking" at power board.
You want to see if any puffed up caps on that board(follow power cord to the board).
If you are not able to do that consider having a shop look at it before more damage can happen.
Here is what to look for if you get it open:
Dec 03, 2012 | LG 52LG70 52 in. LCD HDTV
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My Sony 32inch is blinking in standby mode and won't turn on
Sorry to tell you this i have the same TV.I have just checked the manual it says TO count how many times the light flashes in 3 second intervals.Then turn the tv off and un plug it from the mains.Sorrry then you will have to ring the Sony service centre and explain the problem.
Aug 17, 2012 | Sony Bravia XBR KDL-32XBR4 32inch LCD HDTV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
When I power up my LG LCD TV the power light continuously switches from green to red and the TV does not start up?
Hi,my name is John. Welcome to FixYa. Its going in to protection standby mode. Something in the high voltage is shutting it down. Try to unplug it , wait 30 minutes and try it again. Thanks for Choosing FixYa....John
Nov 26, 2010 | LG 32LP1DC 32 in. HDTV LCD
LG 42CS560 42 Class LCD HDTV Logo
275 people viewed this question
Ekse
RONALD CARTER JR
