Question about Husqvarna Partner Gas Powered Cut Off Saw K960 16"
I have a husqvarna partner K960 concrete saw that the skirt of the piston on the exhaust side has shattered, there is no scoring in the bore, the actually sides of the piston above the damage has no scoring, and the journal and crank bearings have next to no play at all. i can only think of 2 causes which are lack of lubrication or over revving. Any ideas as to why this happened?
Posted by James Ireland on
Repair Ahjoshe
  • Husqvarna Master
  • 885 Answers
If the piston is working in the cylinder properly, that part of the piston shouldn't be making contact with the cylinder wall so lubrication shouldn't contribute to its demise unless it was bad enough to lead to enough heat buildup to cause the failure. It is most likely the metal was weak in a way or spot that the force of the piston going up and down was enough for the metal to finally fail. Of course the faster the motor is turning the higher those forces are so over reving the motor could certainly lead to this type of failure.
Posted on Sep 10, 2012
Hi I have a K960 saw which is a good starter and runs perfect for 5mins after which time it will only tick over - when I try to accelerate it by opening the throttle it then spits petrol back from the carb...
First thing would be to remove the muffler and make sure it isn't plugged with carbon. At that same time you can visually inspect the piston and cylinder. If there is any scoring on either then both will need to be replaced. There are other possibilities too like carb issues or bad crank seals but I always start with the exhaust. You could also take a compression reading if you have a tester. Make sure any compression release (if so equipped) is NOT pushed in. Have the throttle wide open but NO choke and pull 3 to 5 times or until the gauge quits rising. You should see at least 90 psi. If it is around 60 or less then most likely the piston and cylinder are scored or at least the rings are shot.
Aug 24, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
Husqvarna partner 750 concrete saw wont start
You need to make sure it is mechanically sound, has the piston picked up on the exhaust side? does it have enough compression? is there signe of concrete dust on the inside of the air filter and filter houseing?there are many after market carb gasket sets, some have a small hole missing from the diaphram and gasket on the metering side, this activates the compensator, this needs to be there as the metering cover has no breather hole in it.
Mar 13, 2012 | Husqvarna Saws
Husqvarna 450 e-series 18" Chain Saw will not
Is this machine mechanically sound, remove the muffler and take a look at the piston through the open exhaust port, any signs of scuffinf or damage to the piston skirt and the saw will have to come apart for further investigation.
Oct 04, 2011 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna k750 runs for about 5 mins then shuts off. let it rest then restart 5 mins later same thing
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Oct 06, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
My husqvarna k960 won't start I have spark on the sparkplug but i whant start
i know you would like a simple solution. these saws are not simple. check gas for water, clean air filter, check exhaust. take carb off and clean all jets. spark, gas in, exhaust out. fuel line clear? i have seen these **** up so much dust it plugged the breather. hope this helped.
Aug 25, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Oil ratio partner k750
40ml to 1 litre of fuel 150ml to to 1 gallon
May 19, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
My partner 700 cut off saw's carburetor keeps loading up with gas.
you may have a hole in the fuel pump diaphragm,in the carb. Which will let gas into the crankcase through the pulse line
Aug 18, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Partner K750 wont start
i have seen these saws split the diaphram in the carb, so get that carb out and take off the bottom 4 screws... also iv seen 1 with the igniter coil gone weak and only sparking the plug the odd time so make sure yu hav a good spark also...
Jun 06, 2009 | Husqvarna Saws
Husqvarna Partner Gas Powered Cut Off Saw K960 16" Logo
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
robert
ray gallant
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
