Question about Sony XPlod CD Player w/MP3 Playback CDX-GT40W
How can I cd reset MY STEREO - Sony XPlod CD Player w/MP3 Playback CDX-GT40W
Posted by loquillo2012 on
1helpful
My car stereo wont play my cds spits them right out
cd player goosed if it doesent accept cd can try resetting if it has a reset button
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
1helpful
I replaced the battery in my pontiac G6,and now my cd player doesn't work i can't even get the cd player to eject my cd's.is there a reset button some where that i can push to reset the system so that i...
My son has had a similar problem. You can take the car to a stereo shop and they can reset it or you may have to take it to the dealer. The guys at the local stereo shop reset my son's for free.
JVC car stereo problem. It only plays one song on the CD and one station on FM, no volume control or anything else. How do I do a hard reset on it?
I solved it thanks. Push the reset button behind the faceplae with a pin or toothpick, hold for few seconds and it resets.
1helpful
2004 Dodge Ram 1500, Infinity sound system. CD/AM/FM not working.
You most likely need a new radio. They go bad all the time in the Chrysler/Dodge/Jeep. Don't know how many of them I have replaced.
3answers
KD-LX100 working fine, then CD sound stopped working.
That particular cd might have been damaged .
Have you tried with any other cd .
1helpful
Error a0
Do you have a code that you had to enter to unlock the stereo? Have you tried to reset the stereo? Look in your owner's manual and look for a "RESET" button. If you don't have the manual, you can download one from pioneerelectronics.com.. Hope this helps...
1helpful
2answers
How to reset the stereo system
To reset remove your negative battery terminal and leave disconnected for a few moments, re-connect negative terminal and you are reset.
Hope this helps
Sony XPlod CD Player w/MP3 Playback CDX-GT40W Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
