Question about Onkyo Tx-sr607 7.2-channel A/v Surround Home Theater Receiver black
Had a power surge and now my Onkyo TX-SR607 will not power on. Only get a constant click sound. Any repair advice?
Power surge shorted out my unit. Any repair solutions?
Posted by Pete D on
Rommel Cana
  • 5,807 Answers
Although power surge can trigger activations of protection circuits,
there are at times, damage is done before it is activated.
• Check first for low power supply regulators,
then check for possible output stage failure.
let me know if you need further assistance!
Posted on Sep 10, 2012
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
Posted on Jan 03, 2009
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Posted on Jan 09, 2008
Anonymous
  • 4 Answers
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Posted on Jun 17, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: powered sub only has sound while watching a dvd or
So perhaps it's a source sound issue. THAT would best be investigated at the Dish receiver. Consider it's audio settings and how it interfaces with the Onkyo.
Posted on Apr 26, 2010
Testimonial: "I greatly appreciate the help. Went through the audio settings in the Dish and this helped the issue."
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Onkyo TX-SR607 keeps turning off
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
I have no power to my tv it a acoustic solutions LCD37761F1080P
Hi Denise,
Look for a friend that can perform the steps below.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com. Just type the model no. of your unit to the search engine and the available parts will be display.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Mar 05, 2011 | Televison & Video
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My unit 3576 H was working properly. I purchased it about 16 months ago. I was watching TV and not using the hard drive or DVD when the power went out, then shortly came back on. It was connected to a...
Take the unit aparts,check the power fuse on the board,replaced the power fuse,that is near the a/c power cord.Replug it back like 48 hours later,the recoder should reset it self and work,if not ur right it a paperweight,not worth repairing.
Oct 02, 2010 | Philips DVDR3576H DVD Recorder
Power wasw lost to home and after power was restored, the opener normal operations was lost. the opener will only open/close by holding down the button, otherwise the unit only clicks and flashes for a...
First of all whether you repair or replace get a surge protector on this unit 900 joules or higher and this won't happen again. Either the safety sensors are out of alignment and this is a coincedence to the power outage or the power surge has either affected the logic board or the safety sensors or both. You can test the sensors by running them off of a 9v battery. Thanks BB
Aug 17, 2010 | liftmaster Chamberlain Garage Door Opener...
My dell gx270 power supply has been burnt how can i repair it
If the power supply has been burnt, individual electronic components likely failed due to a power surge or other issue, and you may have experienced a short within the unit. Unfortunately, due to advanced difficulty and low cost, power supplies generally are not repaired, they are replaced instead.
Aug 04, 2010 | Dell (1N405) 180-Watt Power Supply
Panasonic 27 in TV
Power surges will attack every board in the unit, it is possible that they discovered that more boards were affected then could be changed for a reasonable cost. These tv's are not component level repair, but board level repair. There is no easy or good solution when a set has been severely damaged by a power surge. The best answer is usually to replace the tv. Also power surges are covered under most homeowners insurance.
Sep 05, 2009 | Sanyo DP26648 LCD TV
I have a harmon kardon cdr 30 cd recorder. After a power outage the unit no longer turns on. A surge must have blown something.
Hi
First thing to do is disconnect the unit from the mains supply for 15 mins to allow for a hardware reset,and then power it up and try again. If it does not come up, then the power supply has been damaged by a power surge associated with the outage. You may have no choice but to take the unit to an authorised HK repairer. Let me know how you get on with resetting the unit. Please take the time to rate this solution. Happy to talk to you more about it. Cheers
regards robotek
Jul 15, 2009 | Harman Kardon CDR30 2-Disc CD Recorder
Fisher Paykel Active Smart fridge turned into storage unit by power surge
I would unplugg the machine for 5 minutes, plug back in again and close the freezer door, open fridge door and press the mode button
Jun 22, 2008 | Fisher and Paykel Active Smart® E522BR...
Tv power will not come on tried un pluging and pluging in diffrent outlet still will not work
You did not say if any lights are lighting up on the unit. If the red LED is lighted or blinking your power supply, and fuses, are probably OK. If the LED is blinking it means that you probably have a problem in the high voltage circuit. Usually the Horizontal Output Transistor is shorted. Could be caused by a power surge, lightning strike or shorted flyback. If you know TV safety, how to use a DMM, soldering techniques and are good with tools you might be able to fix this. Unplug and open the unit by removing the back. The HOT is near the flyback (a large round cylinder with a large red wire coming out of it) usually on the right side, mounted to a large piece of aluminum (used as a heat sink). Using a DMM check the HOT. If shorted this is your problem. Replace the HOT and the flyback. Check all resistors and diodes in the circuit for problems and replace any out of specification. This may solve your problem. If not the HV Block could be shorted also. This is part of the same circuit and is where the wire from the flyback goes. If after replacing all these parts the unit still is not working you will proabably need a repair tech to look at it. If you do not feel confident doing any of the repairs listed above seek the help of a reputable repair shop. This repair should not be very expensive in relation to the cost of the set. Good luck.
Jul 21, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Onkyo Tx-sr607 7.2-channel A/v Surround Home Theater Receiver black Logo
418 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
