Question about Ryobi Lithium Ion 18 Volt 18v Cordless String Trimmer Edger Weedwacker P2002
Cross section of ryobi 18v trimmer
My ryobi 18v trimmer won't run.,..quit w/o warning. Battery powers other tools. Help!
Posted by Sassie Guptill on
Bradley Bull
    New Friend:
The wiring maybe disconnected, either at the switch or down near the head of the trimmer
Posted on Nov 26, 2013
5 Related Answers
Anonymous
SOURCE: Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Posted on May 18, 2008
Anonymous
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
evwood
Paul Evans
  • 50 Answers
SOURCE: I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
Posted on Jan 03, 2009
Anonymous
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
Anonymous
  • 85 Answers
SOURCE: Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Posted on Aug 19, 2009
Can I buy a battery charger for a ozito drill
hi Terry.
you could try homebase.or ebay will have them.
or this link should show you where you can buy them.
battery charger for ozito drill Google Search
Dec 02, 2017 | Drills
I have Ryobi P2031 18V LiON trimme; other day it quit; is not the battery: hidden fuse?
Did you load test the battery? A volt meter will only indicate battery voltage...but not amperage. Only a load test can do thay. There is no fuse, however the switch or motor could have failed.
Sep 01, 2016 | Ryobi Garden
Ryobi troubleshooting
The motor may have overheated and burned open. Use a multimeter to check resistance across the battery contacts in the tool with the switch closed. If it reads open, the motor has failed.
Jul 18, 2014 | Ryobi P2005 18v 12" String Trimmer Edger...
Electric ryobi weedeater with good battery won't start
Ryobi Trimmers unscrew halfway down the shaft (so it fits in the box). If this gets loose, the trimmer will stop working. Simply tighten the connection between the upper and lower half.
Mar 31, 2013 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
Sep 26, 2012 | Ryobi Garden
I bought a this edger brand new, but have misplaced the instruction manual before I've even taken the edger out of the box. I looked on line & don't see where a manual is available. I...
You can look in the manufacturer web page , under manuals or just go to home depot web site and look for your model , scroll down and you will see product info and manual .
Oct 12, 2017 | Ryobi 18v 12" Cordless String Trimmer And...
Should I bring the battery of my Ryobi 18v grass trimmer inside for the winter?
Yes, and charge it up occasionally to keep it alive. Lithium batteries are costly and severe cold is not good for any type of battery.
Dec 02, 2010 | Ryobi 18v Lithium Grass Cordless Trimmer...
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi Lithium Ion 18 Volt 18v Cordless String Trimmer Edger Weedwacker P2002 Logo
1,001 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
bryan st
Tim Venetis
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
