Full line digarm
I don't know what a full line digarm is, but you can download service manuals using the links below:
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: set the carb for a mcculloch 3516 chain saw
Carburetor Adjustment
There are no hard and fast settings.
A good initial starting point for the "H" and "L" needle valves are 1.5 turns CCW from lightly seated.
The "T" adjustment enters here (idle speed) and there is no initial setting without a tachometer, depending on age of your saw there may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Start with a fresh mix of fuel. Put ALL of the old mix in any 4 cycle engine and start new. I suggest 50:1 regardless of what your manual says.
• CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; once marred adjustments are difficult to impossible to set properly.
• Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
• Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
Now we adjust for performance. The best performance adjustment procedure I have found follows.
Madsens Shop & Supply, Inc. Carburetor adjustment (All saws homeowner and professional are the same)
http://www.madsens1.com/saw%20carb%20tune.htm Read step 4 (allow it warm before making adjustments).
• There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment is often indicative of a larger problem.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
SOURCE: Fuel lines rotted off of my McCulloch 4600 chain saw
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope this helps!
SOURCE: I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
SOURCE: what is the proper fuel mix for a mcculloch ms1635
between 32:1 and 40:1 - Manufacturer recommends 40:1 Ratio - EXAMPLE: "Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio."
