Yamaha RX-V361 Home Theater Receiver Logo
Anonymous Posted on Sep 09, 2012
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Hannes vd Merwe
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Sep 09, 2012
Hannes vd Merwe
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
10983
Points
88
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.I cannot figure out how to get sound through my Ya - 9_9_2012_6_50_32_pm.jpg
  • 1 more comment
  • Anonymous Sep 09, 2012
    I am not using any other boxes besides the receiver and TV. i plugged in the rca red and white cable into the TV and the other end into the receiver but still no sound. I turned off my TV speakers to see if that was the problem but still no sound.
  • Hannes vd Merwe
    Hannes vd Merwe Sep 10, 2012
    Ok. I have done some searching, and LG specifies that the RCA must be used for other monitors etc. To get the sound to your receiver use he OPTICAL output at the back of your TV. - it is a black square and you need an Optical cable for this. Connect this to the Optical IN on your receiver. It is labelled - DIGITAL INPUT on the receiver. Remember to also set your recieier to accept Optical input on that channel
  • Anonymous Sep 11, 2012
    My TV does not have an Optimal output. Only HDMI and RCA plugs. i am thinking I might not need something else to get the sound out of my TV into my receiver. Thanks for all your input.
5 Related Answers
A
Anonymous
  • Posted on Jun 18, 2008
SOURCE: crackling sound through speakers while watching dvd movie
Yamaha Rx-V361 Firmware Upgrade, A/V-Receiver/-Verstärker - HIFI-FORUM
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Jun 04, 2009
SOURCE: Yamaha RX-V361 cuts off: check SP cable
Disconnect the speakers and turn on. If your receiver is ok, it will not go into protection "check spkrs" Then connect speakers, one by one, each time make sure the receiver is off, then turn it on. When you find the speaker that's causing the problem it will go into protection. At this time, disconnect the speaker at the speaker, then turn on again, if it still goes into protection, you have a speaker wire problem. If it stays on, you have a problem with the speaker. If you have a multimeter and know how to read it, check the impedance and the resistance. Check the internal workings of the speaker, bad surround from dryrot or smoked crossovers, etc. look for the obvious first. Hope this helps
gregory ferreira
  • 269 Answers
  • Posted on Oct 26, 2009
SOURCE: I have a yamaha receicer
Is the mute on?Reset the menu to factory default
Marek Podmaka
  • 127 Answers
  • Posted on Mar 02, 2010
SOURCE: Yamaha RX-V361 DVD cuts off w/ check SP cable
This message means that speakers are not connected properly. What is their impedance? What is the impedance set on the receiver via Advanced Setup menu (see manual)? Check if it is not short-circuited.
Try the receiver without speakers connected. If the message goes away, receiver is OK and problem is in the connection to the speakers.
Anonymous
  • 14 Answers
  • Posted on Apr 17, 2010
SOURCE: I have a Yamaha receiver Rx-v361. Suddenly no
Sounds like the receiver needs a proper burial.
Try Fm radio with stereo mode to see if you can get 2 speakers to light up.
Hope this helps.
Pairing Samsung remote to Yamaha RX-V361
Normally makers don't play ball between each other. Yes if it was a Samsung Television and a Samsung Receiver A/V System. Or if you have something like a Cable Box or Satellite System that is made to interact with other makes. Or if it is a Universal Remote.
I think you were just lucky that it happened to use the same frequency. Look in the manual for a scan command.
https://www.google.com/search?q=Connect+Samsung+OLED+S90+remote+to+Yamaha+RX-V361+via+optical
Yamaha rx-v361 turns on and off
If it turns off while playing, it might be tripping a overload circuit and resetting. Try it will just a couple low watt speakers connected and see
I have a yamaha Rx-v361 i get sound when in DVD mode, SAT mode but no sound in TUNER or AUX (MP3 player) modes, i checked all the wiring in the back of the unit and everything is connected. please advise
Tuner is internal so there's no way wrong 'wiring' could be the problem there.
Does the tuner actually 'tune' a station?
If you're using V-Aux on the front panel for your MP3 player, make sure you haven't assigned V-Aux to a digital function. Page 48.
http://www.retrevo.com/support/Yamaha-RX-V361-Receivers-manual/id/2526ci758/t/2/
Yamaha RX-V361 DVD cuts off w/ check SP cable message
Turntable connection
Yes, you'll need to purchase a PHONO PRE-AMP, and then connect the turntable to the pre-amp, and the pre-amp to the LINE INPUT of your receiver.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
