eMachines E442 E442-v133 15.6" Notebook Amd V140 2.3ghz Cpu 2gb Ram 120gb Hdd W7 Logo
Anonymous Posted on Sep 09, 2012
How to fix no boot device on emachines e442 for free
MY COMPUTER SHUT DOWN ON ME AND NOW I CANT REBOOT OR FIX . IT KEEPS SAYING NO BOOT DEVICE OR BOOT DEVICE MISSING
Anonymous
Level 3:
  • eMachines Master 32,281 Answers
  • Posted on Sep 10, 2012
Anonymous
eMachines Master
Level 3:
Answers
32281
Questions
Helped
7912590
Points
102259
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
1 Related Answer
Azrael SRL
  • 11800 Answers
  • Posted on Feb 09, 2011
SOURCE: i have a emachine notebook
The motherboard no longer detects a hard disk present - it has died. Replace it and reinstall Windows using the recovery cd that came with the laptop.
1helpful
How do I fix an ASUS Transformer Book TF101 that's stuck in boot?
  1. Press and hold Power and Vol- until the device reboots and small white text shows up saying press Vol+ within 5seconds for recovery. Do not press Vol+.
  2. It will then prompt you to cold-boot in to either recovery or android, follow the directions on screen to select android and start.
That seems rather annoying to have to do every time you restart the ****** thing. The permanent fix requires either root access via terminal emulator under the installed version of android, or running a remote shell on it with the Android sdk. I chose the latter.
As with all ASDK tomfoolery, start the adb server
adb start-server
Check to make sure the device shows up
adb devices
Start the required remote shell session
adb shell
Run the follow magic command to make everything happy again
echo boot ' dd of=/dev/block/mmcblk0p3 bs=1 seek=0
And then reboot the device.
reboot
I dont have a boot disc, and pc keeps saying to reboot and select proper boot device please help
Try a new battery charge overnight before doing anything to computer.after overnight charge look on side of computer for a very small hole. Insert a thin needle push in the reset the computer should reboot if it does not have all file take down model and brand go on Internet and order boot disc system for 10.00 when you receive disc load computer will WORK GUARATEED!!!!
How do i fix Reboot and Select proper Boot device?
The system is trying to boot from a designated device (like a usb drive, an iso file or a mounted drive) that doesn't have a boot partition on it.
Go go into the boot select order and change the setting to a bootable drive
AMD Phenom X4 9500 quad-core LX6200-01 reboot problem
Hi to fix this problem go to bios settings and there select the hard drive on witch you've got system files then save and reboot. If you need more help let me know.
Emachines e442 v133 laptop Powers on to just a black screen
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
My computer keeps saying reboot and select proper boot device. Please tell me what do I do?
on startup press f2 or del key to enter bios setup,configure boot option selecting 1st boot device as hard disk
After reinstalling OS, my computer will not reboot saying hal.dll is missing. When I tried the recovery disc, I recieve the "bootmgr is missing" message. What do I need to do now?
FORMAT AGAIN
press delete at  startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
My computer keeps saying reboot and select proper boot device or insert boot media in selected boot device. how do i do this?
Seems like an issue with the hard drive.
Try resetting BIOS.
If that doesn't help, u will have to check whether your hard drive is good.
2helpful
2answers
Computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
Pc keeps trying to start up but states it needs to reboot and won't. I have tried to insert the operation disc and it does not work either
it probably says insert suitable boot device. If you are trying to boot from a cd go into the bios and set the boot device priority to CD as priority. If hard drive then set hard disk to the top.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
