Machine went through entire cycle and I was able to open door, but drum still full of water. I ran the drain cycle without the clothes in but water still didn't drain. What can you suggest?
SOURCE: FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
SOURCE: zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
SOURCE: Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
SOURCE: zanussi washing machine has stopped in the middle
Remove the drain outlet hose from the outlet , and lay the hose down into a bucket or similar, and the water should syphon out, thus enabling you to open the door.
Check the filter after you have done this.
Hope this helps.
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect.
If the
water flows then the flow should be good, if not the inlet valve is bad or
there is dirt in the filter. Also check the flow at the inlet of the water
line. Once the water comes into the system the WATER LEVEL SENSOR - normally a
pressure switch- must activate at the preset/chosen level to give the signal to
the program controller to switch on the motor. What is most important for the
motor to start functioning is that the door switch must be ON when the door is
shut or this will be an error for starting the motor for rinse and wash.
Check this
link to replace the inlet valve:
Finally
after the wash the drain valve will be activated, the water is allowed to come
in to rinse and then finally the dry spin with the drain valve/pump activated
so as to drain off all the water from the clothes during the spin.
Make sure
that a fault in any of the cycle will relate to the specified action, so check
the command from the program module and then the executing device be it the
valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
