My tractor will run and continue to mow if I keep the hood up in the air while cutting. If the hood is closed the tractor will stall after about 1/2 hour. If I turn off the pto the tractor will continue to run. I cleaned the carb and put in a new ignition module still same problem. Any suggestions?
Sounds like you've got a bunch of debris around the engine, not allowing it to cool properly. I'd pull the shroud off the engine, and clean out any accumulated debris and clippings (considering your symptoms, I'd expect a lot of it. My preferred method is to use an air gun connected to my compressor - I don't like spraying under the shroud with pressurized water.
SOURCE: PTO Clutch keeps burning up or melting. Has good
do have the right clutch if so u might want to check into may be see if u can get bigger clutch than wat the factory offers
SOURCE: I put a new battery in my cub riding mower (2166).
Look at all of the safety interlocks: seat must be down, drive must be in neutral, brake must be on, blades must be off, etc.
Gary
SOURCE: Cub Cadet 2166 tractor, changed transission filter and oil
did you check to see if your belt was in good shape and if the hydro relef was in
