Question about Apacer Memory Apacer HT203 Hard Drive
My Apacer hard drive won't connect to my apple Mac, why?
Posted by gary_skirrow on
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Oct 01, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Mac mini hard drive replacement
apple mac mini 1.5 intel core solo 60gb
Aug 21, 2012 | Apple iMac Computers & Internet
How do i down load piactures from casio exilim to mac apple computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 03, 2012 | Casio EXILIM EX-H30 Digital Camera
How fix Loud g4 Hard Drives
Not sure what you mean by loud Hard Drives. Hard drives are so quiet you can barely hear them. If they are loud the only cure is replacement. However, I have never heard a hard drive that I would consider 'loud' in all my years in computing./ As you show a mirror fronted mac in your question - I think you may mean loud 'Fans'. This mac was notorious for its loud fans. They can be replaced, but I seem to remember a firmware fix from Apple to slow them down - or it may have been a 3rd party utility.
Apr 01, 2012 | Apple Power Mac G4 Desktop
My mac won't accept dvd's
This sounds like a dvd drive problem. I would go to your nearest mac store right away. theres nothing you can do at home without risking warenty
Mar 29, 2012 | Apple MacBook Pro Laptop Computer with...
How to get photos off of old mac hardrive. It stopped working
Hi Cindy. Is it the Mac that has stopped working or the hard drive?
If it's the Mac then the drive is probably OK and can be accessed though anopther mac after removing it from the Mac chassis. If the Mac will power up then it's drive can often be accessed even if the mac itself won't do anything.
If the HD itself is not working then things are more difficult. It is most likely going to cost you regardless of the nature of the failure. Failed HD recovery is not cheap. It just goes to shjow that when we kept our photoghraphs in a shoebox under the bed all we had to worry about was the house catching fire.
Backups are cheap. when you get this sorted, the very next thing you must do is get a back-up drive.
Jan 24, 2012 | Apple iMac Desktop
8gb flash drive won't work in my old mac lap top, trying to put files backed up from another drive on it
When you plug it in does the mac laptop even register that it has been connected? I'm also assuming the usb drive works on your other computer?
Aug 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I pluged in wrong power supply to external hardrive there is a light flashing so there is power but my laptop cannot find drive can i retrieve my data
The drives in these units are pretty standard SATA or PATA drives.
Personally, to retrieve data in these situations, since it's the USB converter board that is likely damaged, I open up the box and take out the drive, and put it into a PC that's running MACDrive (software that lets a PC use a MAC formatted drive)
You may however simply be able to get another external drive enclosure (about $20 USD such as THESE) and put the drive into it and be up and running again on the MAC with the old drive in the new enclosure.
If the link doesn't work paste this link into your browser's address window:
http://www.tigerdirect.com/applications/category/category_slc.asp?Recs=10&Nav='c:2778'&Sort=4
Apr 24, 2011 | Apple Computer 1TB Western Digital My Book...
New hard drive not recognized on mac pro
OK what you could do is connect up that drive to a PC and format it with NTFS, & then put it on the Apple, it should then "See" the drive.Then you can work on it via the Apple.
Jan 29, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Apacer Memory Apacer HT203 Hard Drive Logo
55 people viewed this question
Top Apacer Memory Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Apacer Memory Computer and Internet Expert? Answer questions, earn points and help others
