My Vauxhall Astra's remote has suddenly stopped working, although the boot does gets locked. There is no sound and light signal anymore. I have replaced the battery, doesn't help. Locking with the key on the driver's door doesn't lock all the doors. Note: A mechanic (not electrician) was looking at the fuses as the cigarette lighter was not working. Could he have messed up the fuses? Although I matched them with the booklet later and saw only minor, like 10 A instead of 15A etc. At least it should work.
SOURCE: Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
SOURCE: 1999 Audi A3 1.8T Electric Windows and Central Locking Won't work
will your passenger door open with the key and is it just one side that your windows are not working or both. if its just one side it might be your regulator motor in the door thats not working if its both it might be your central locking pump usually in the boot. however if both of them are working fine it could be that your key needs reprogrammed however i think the 1st 2 are more likely to be the problem.
SOURCE: How do I remove drivers door handle that key will
Central lock dosen't respond ,put the lights are flashing!Where I need to look my problem?
SOURCE: N REG VAUXHALL CORSA CENTRAL LOCKING NOT WORKING
central locking on my 93 corsa with standard key, not electronic type as used on later models, all doors are locked and refuse to open, ive checked fuse and thats ok, doors refuse to open from inside the vehicle and from outside, only the tailgate will open from the key, any ideas ,,, thanks dave
SOURCE: mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
