Question about Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa
Weiser lock diagram
Is there a diagram of parts and where they attach
Posted by Rollin Stapp on
Coaltowner
  • 963 Answers
The installation instructions:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Posted on Sep 10, 2012
Weiser lock powerbolt only goes half way and a green light flashes 5 or 6 times with a beep, how do i fix
Brent, Try resetting initialization/ installation or contact weiser. Attached you will find links to your manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.weiserlock.com/pdfs/instructions/electronics/smartcode.pdf
http://www.weiserlock.com/PDFs/instructions/Electronics/5062000-Powerbolt2-Instructions-eng.pdf
http://www.weiserlock.com/en/customerservice/productsupport/supportcontact.aspx
Weiser deadlatch replacement
Most post style latches will work on these.
My Weiser Lock unlock fine using the touch pad but will not lock using the touch pad lock button
For your unusual problem I suggest that you call Weiser Lock during business hours at one of these numbers:
For assistance call
1-800-343-9652 USA
1-800-501-9471 CANADA
or visit www.powerbolt.com
Constant humming from lock
Troubleshooting instructions for the Weiser Powerbolt can be found here:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Any misalignment of the parts can cause a mechanical bind in the lock if it is otherwise trying to operate.
Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Can i get a new touch pad for weiser power bolt 1000?
the part can be found here:
http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa Logo
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
