I have used the easeus program but can only recover the one gig without purchasing it. I need a program that I can save to a flash drive to put into the crashed computer to recovery the remaining photos.
There are many freeware and pay data recovery programs available on the web Try this freeware call smart Data Recovery http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html File recovery has never been easier thanks to Pandora Recovery. The program's wizard-like approach to finding and retrieving lost files will appeal to all users. http://www.piriform.com/recuva Accidentally deleted an important file? Lost something important when your computer crashed?
http://www.smartpctools.com/recovery/ind...
This is different from other recovery software because it not only recover lost file from harddrive and floppy like most do, but also recover from removable media like flash drive.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
hope this helps
Testimonial: "thank you you were great help"
Don't worry, now you can recover own important data item from crashed hard drive using Kernel for Windows Data Recovery Software. It is the first choice of data recovery experts. It provide better solution without data loosing.
Using this tool you can also recover corrupted and deleted file, folder, image, audio, video etc from FAT/NTFS partitions. It also allow users to recover data from PEN, ZIP, SATA, USB, IDE, EIDE, drives. It is supported by all Windows OS. Know complete detail about this tool and download free trial version visit http://www.nucleusdatarecovery.org/windows-data-recovery.html
There are still many data recovery freeware
available online that can do a great in photos recovery, except Easeus.
I would recommend you to try a PC data recovery freeware that can easily restore your computer photos back:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
This freeware was found by my boy friend
when his PC was completely formatted. But, he finally restored all his wanted computer
files back with this data recovery freeware successfully.
Note: You'd better not save anything new on
this computer before you've restored all your photos back in case of data loss.
Next time, I hope you could learn to back
up everything important at least on two hard drives.
SOURCE: Need driver for SD Card USB Drive for Windows 98
Check these driver :
1) http://www.lowrance.com/Downloads/Drivers-and-Firmware/MMCI-USB-11-Drivers-LEI/
2) http://www.sandisk.com/retail/driverdownloads.aspx
SOURCE: Windows xp professional won't complete setup.
Its an hardware error. You have tech support with MS since you bought the new XP try to see if they can tell you what is the hardware its complaining about.
SOURCE: Hi. I accidentally deleted my folder on a USB
go to google site and type free recovery software there is somany tryal vrsion just downloard that
SOURCE: I have purchased a new hp Pavilion dv7tQuad laptop
Sounds like an update installed incorrectly or has been corrupted. Using Add remove programs remove the MS Office You have installed. Before you let it reboot tell the computer to run Check Disk on your primary hard drive and reboot the computer. Once the reboot is complete re-install MS Office and see if that solves the problem.
SOURCE: Two computers ago, and two
Wndows installers have changed over the years, so it's not a surprise that the program couldn't be reinstalled. The Roxio Photosuite 8 is listed as a Win2000-XP product; so it may not be the correct release for Win7 either unless you use a workaround. Look here for the current Roxio slide show products: http://www.roxio.com/enu/store/photo.html?rTrack=m_pro_photo
Workarounds: go with a dual-boot or virtual computer system. Win7 Pro and Ultimate let you run a virtual XP computer for free (download two programs - the virtual PC software and then XP mode). All other choices will require a licensed version of XP installed either in the virtual computer program or in a second partition for dual-boot. I've found that files can not be transferred directly from XP mode to the real computer; they must be stored on external media. Then install your software as you would on any stand-alone computer.
I hope this helps.
there are many freeware data recovery programs available on the web
http://majorgeeks.com/Free_File_Recovery_d6792.html
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer.
This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses! http://download.cnet.com/easeus-deleted-file-recovery/3000-2248_4-10867160.html Hope this helps
EASEUS Deleted File Recovery is a powerful and free file undeletion solution for Windows 2000, XP, 2003, Vista, 2008, Windows 7. It is capable to recover lost files even after a deletion or even when recycle bin has been emptied. It can undelete files on any valid logical disks visible by operation system. In the case of damaged disk volume or partition, please use EASEUS Data Recovery Wizard. EASEUS Deleted File Recovery is an easy-to-use program with a Graphical User Interface without technical skill requirement through the whole recovery process. Simply launch the software, specify the disk where lost data located, click "Next" button, all the deleted files will be listed. Bonus its free
thank you so much
hope it all worked out for you
