Question about Samsung 4 Channel Dvr
Samsung sde-4001 reset - Samsung 4 Channel Dvr
Posted by Don K on
1 Related Answer
mobil master
Computer Repairing
  • 14641 Answers
SOURCE: need to reset password on my samsung sde-3004n
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Oct 31, 2012
Changed my admin user and password on samsung dvr sde-4101n And forgot password how do I reset it
there is reset button on the main board in dvr you can press it to get default pass
Mar 14, 2016 | Samsung Home Security
Forgotfactorypassword can i reset
hard reset code type to your home screen
hard reset for samsung *2767*3855# wait the automatic restart then finish 1st step you can do is? go to setting get started to set any thing you want thats all
Jul 05, 2015 | Samsung SDE-3004N 4 Ch Security System,...
How can I reset My Samsung sde-5003n back to defaults?
Suggest using Google to access a copy of the manual. Some units have a reset function, other are like a computer with an internal battery or reset button.
Aug 02, 2014 | Samsung Security Products 16 Channel DVR w...
How to reset admin password on a Samsung sde-4001n security DVr
Thank you the 4321 default password worked on the Samsung vr sde40014n
again thank you
[email protected]
Feb 24, 2013 | Home Security
Remote and mouse do not work on samsung sde 4001 security system
Easy fix...because you are using VGA screen ...you need to push pretty fast on your remote the following ( do this twice) fast....push. Freeze. View. Return. That should fix it. If twice oes not fix it keep doing it...it will work. Good luck.
Dec 28, 2012 | Samsung Home Security
Need to reset password on my samsung sde-3004n
Oct 29, 2012 | Samsung Sde-3004n 4 Channel Dvr Security...
How do i view my security system on line using my apple laptop system is sde 4001
You won't be able to access the system from a different network without changing some settings in the router. You will need to find out what ports the security system uses. If you bring up a web page to monitor/configure the system, then you'll most likely use port 80 (HTTP) or port 443 (HTTPS). If you see "www.something.com:3948", the port is the number after the colon.
You will need to go into the router and enable port forwarding to the IP address of the security system.
Oct 22, 2012 | Samsung SDE-4001 8 Ch DVR Security System,...
DVR SDE 120 can't reset 4321 thanks
There is no mode or channel 2 button on the SDE-120
Apr 27, 2011 | Samsung 4 Channel Dvr
Samsung 4 Channel Dvr Logo
Top Samsung Home Security Experts
Mike
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
