The display lights up but there is nothing on it. Can't use the microwave or the oven. The stove top works.
SOURCE: Microwave
This is a problem with the control board assembly, which we repair nationwide for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: sharp microwave oven model r-1850
Are you saying it's dead, with no display and no inside light when you open the door? And the fuse is good?
If so, you may have a bad magnetron temperature fuse. This device looks similar to the attached photo and is located near where the magnetron mounts.
You can usually find exploded views entering your model number at the Sears parts site.
The best place to order Sharp parts is Tritronics.
disassembly information at our site, and our link is at our listing here on FixYa.
At
our site, we have a video showing how to remove a typical
over the range control panel assembly in under 5 minutes.
SOURCE: Sharp Carousel Microwave R-1505
There are two options for this model:
1.
You can order our exclusive modified control unit (part # CU150) with our proprietary upgrades
for $95, or add $15 for a new select button assembly making it part # CU150B for a total of $110.
Then if you return your defective control unit in repairable,
good cosmetic condition, we'll give you a core refund of $30.
It comes with a one-year guarantee. For
details, see: http://www.microwavedisplay.com/exchange.htm
2. We can repair your existing control unit for $39.95 in about a week or so with a one year guarantee.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
William E. Miller, AS-EET
[email protected]
SOURCE: microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
