More likely a fuel problem. Tap the choke when you put it in gear and see if it picks up. If so your idle mix is to low or you throttle link is picking up to soon.
I have a 2012 dodge ram 1500, I am wanting to raise it 2 inches with a leveling kit, I will need to readjust the fog lams and headlights, I know how to do the headlamps but need to know how to do the fogs lamps?
Thanks
It sounds as if you have set a code in the transmission. This should be accompanied by a light, or a message in the drivers information module. You have entered a limp home mode, and the car will only perform limited functions after that. You will need to have the transmission control module scanned for codes, and a solution can be found after that. If your in Maine look up my shop on the web at expertvolvo.com
theres many things that can be the cause,instead of having people tell you to try this and that,change this and that,scan codes it will point you at problem area and start from there
