ASUS DISPLAYS are pretty FUZZY, HARD TO REPAIR but also HD and VIVID. ASUS DISPLAYS are usually HARD SEALED from the inside. Try paying it a rest and RESTARTING . Doesn't work? , DETACH the STAND to make it easy to work. The SCREWS to OPEN an LCD MONITOR are usually near the VGA/DVI/HDMI CONNECTORS. HOPE THIS HELPS.
SOURCE: driver problam
what video card are you using? normally you will not need a driver for a monitor.
does your video card support the lowest resolution the monitor you brought?
SOURCE: asus 19inch LCD monitor keeps
The Auto knob maybe mechanically stuck or the internal switch may be defective.
Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement.
Do rate the solution.
Samir
