If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.generalappliancesvc.com > why-you-shoul... Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
make sure you have selected convect bake, otherwise remove oven from wall to acces the back and test voltage at the fan, most likely the fan is bad, if you use conv. bake alot
this could be due to more than one cause
selector switch faulty
elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom
also worth while looking at the wiring to the convection elements.
does the thermostat neon come on when convection is selected?
