Question about Sony 2003 2004 03 04 Infiniti G35 Bose Am Fm Radio 6cd Changer Cassette
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
Checked fade and bal controls rapped on radio and amp and nothing just dead. Back speakers work fine.
Posted by Gary on
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Feb 03, 2016 | Nissan Cars & Trucks
Hi I have just bought a infiniti fx 35 2004. Every things works perfect on factory head unit like radio or cds and can operate it from steering too. But cant hear any sound from the speakers at all . I...
You can start at the front or the back.. You have to trace. Start on the output of the amp..If everything is fine there go to your output from the unit itself..good luck
Jun 07, 2013 | Cars & Trucks
2000 oldsmobile bravada factory bose system 4 of six speakers just died
The amp fuse should be in the fuse box in the dash, it is fuse 20 and it should be a 25amp fuse that is clear in color. Although looking at the diagram, all the speakers go through the factory amp. So you may have another issue.
Jun 28, 2012 | Oldsmobile Bravada Cars & Trucks
Sound is chopy
What is the source of the choppy sound? Cable box? When you say it fades do you mean it gets quieter or does it just blink off? Digital signal problems will cause the latter. You might check the cable box or call your cable provider about it.
Apr 03, 2010 | Mitsubishi WD-65731 65" HDTV
CAN THE BOSE CD PLAYER BE FIXED IF SOMETHING IS
Yes, many aftermarket radio/CD players are made that will fit. Look on WWW.Crutchfield.com
Feb 07, 2010 | 2000 Nissan Maxima
Front speakers only produce static
The amps are on each of the speakers. There is a place in Florida that will fix them for around $85.00 each plus shipping. I put a sony unit in mine and replaced all of the speakers with the kicker ds series for less than fixing the bose system.
May 29, 2009 | 1991 Cadillac Seville
Infiniti G35 speakers don't work
03 and 04 G35 vehicles had a Technical Service Bulletin issued regarding the audio circuit board. No sound was one of the symptoms of a faulty circuit board. There was a design flaw with the boards on the early model G35's that was corrected in 05.The audio units on those cars consisted of three pieces, the radio itself, which is just a silver box, a circuit board that attaches to the front of the radio and then the outer display. I would suggest contacting a dealership service dept. with your VIN number in hand, and ask if the circuit board has been replaced. Even if it has, It will still more than likely be the problem. It's either that or the radio
Apr 27, 2009 | 2004 Infiniti G35 Sport Coupe
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Sony 2003 2004 03 04 Infiniti G35 Bose Am Fm Radio 6cd Changer Cassette Logo
403 people viewed this question
Top Sony Car Audio & Video Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
