Televison & Video Logo
Posted on Sep 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Needed a code for a universal remore control for emprex tv
Level 3:
Top Expert:
  • Radio Shack Master 76,851 Answers
  • Posted on Sep 08, 2012
Radio Shack Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987343
Points
237762
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
5 Related Answers
Anonymous
  • 207 Answers
  • Posted on Apr 10, 2008
SOURCE: philips universal remote codes
http://www.urc.philips.com/
Anonymous
  • Posted on Apr 11, 2008
SOURCE: RCA XL100 Remote Code?
I found a remote on the web for that model and purchased it.
Anonymous
  • 4 Answers
  • Posted on Jan 16, 2009
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
frank_crab
  • 233 Answers
  • Posted on May 30, 2009
SOURCE: help with GE universal remote control need code for magnavox TV?
Try this link and select the RCR451 and try the codes for it, if they do not work try the one for the RCR 460 one. Just scroll to the bottom of the page and look for the word next, click it and you should see the 460 on the bottom left.
Anonymous
  • 814 Answers
  • Posted on Jun 22, 2009
SOURCE: rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
NECESSITO CODIGO PARA REMORE CONTROL CHUNGHOP RM139 EX PARA USAR EM TV PHILIPS
English only on Fixya.
Philips TV remote codes. If you have recently bought a universal remote control and you need the remote codes to operate your Philips TV, we have codes below for your TV that should be working. If the first does not work keep trying the numbers down the list.
Philips HDTV CODES
1129
1236
1237
1239
1261
1334
1351
1390
1411
Philips TV Codes
1004
1007
1011
1017
1018
1047
1053
1056
1057
1059
Using an universal control remote remore,what is the code # to use a Polaroid tv?
Press and hold the CODE SEARCH/SET UP button on the remote until the Indicator LIGHT lights, then release.
Press and release the button for the device you are programming (TV, DVD, VCR, etc.
For AUX press AUX then the device Button you are assigning to AUX. God Bless.
I have aphillips energy star digital tv i have a ona13av269 universal remote.how do i program
Find on your Remore's manual the approiate code and feed it according to instructions
you can download the manual from here
How to activate the remote to an emprex tv
you must read your owner manual download from
www.retrevo.com
or download your code from
www.remotecodelist.com
God bless you
I have a sharp tv/vrc combo without a remote. I'm using a universal remote but wont let me get into the menu. I need to change it from cable to air. Can someone help?
For sharp TV-VCR Combo with universal remore control,
1/ Start by pressing SET & TV at the same time, the LED goes solid RED
2/ Press 009 or whatever code works for your TV.
3/ Confirm that you can now use your control to flip channels..
Then,
4/ Just press the blue button 2-/12. That allows you to change from cable to air and vis-versa. Hope that helps.
Ade
I need the remote control code for an old GE TV,
0704,012,0018,0002,0502,0006,0007,0601,0835,
0901,0114,0103,0803,0806,0310
10helpful
2answers
REMOTE CONTROL CODES FOR EMPREX TV
Emprex uses the Memorex codes. They are 1002, 1004, 1005, 1010
Have sanyo remore u230 need codes for phillips tv
Philips TV codes. 204 232 211 216 217 228.
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
