The top drawer of the freezer is being hindered by the door and I cannot remove it
SOURCE: Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
SOURCE: I have a new Samsung RFG297AA fridge and I am
this could be that your gaket may be sucking in air.check gasket dollar bill trick.put dollar half way in freezer and pull it out.if it pulls out easy your gasket isnt sealing.be sure to go all around the freezer gasket with the bill.
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
SOURCE: I have a Samsung fridge model RF265AB. We can her
The problem is on your fan motor. This fan will automatically off when the door open. It has the switch that activated by the door. Please check and fix your fan, since it work with strong noise. The problem is usually on its bearing.
Regards
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
